Shift Problems
RoadDick
Hello everyone, I'm new to the forums and would like some experienced opinions on a shift issue I can't seem to resolve. Here's a quick summary:
1987 BAJA
205HP/4.3 MERC
ALPHA ONE/GEN. ONE
Installed a new lower cable last July which currently does not bind and will shift the drive easily when unhooked from the kill switch assembly and upper cable. Kill switch works and adjusted out to 1/8 inch travel. New control box installed last July as my old one finally gave out after 20 years. Installed a new impeller kit last week and realigned shift shaft to mate up with shift lever(pointing forward). Adjusted both cables out according to Merc specs(6 inches center to center on lower cable) and spent last Saturday on the lake until I noticed that the travel required to shift the boat into FWD was requiring more and more travel until it was all throttle and no shift. Reverse was no problem.
Pulled the boat from the water, replaced the upper cable last week( once again a 20 year old part), adjusted to specs again and can't seem to find the sweet spot without the clutch dogs clicking and a slight increase in throttle. Finally it will catch in both, however it requires too much control handle travel and a firm clunk from the dogs which we all know is not a good thing.
Question at hand: Does this sound more like a bent shift shaft,Shift shaft lever issue or some other issue? Something I overlooked?
Re: Shift Problems
Ayuh,....
I can't think of any Secret tricks to fix it,...
It sounds like you just Screwed it Up somewhere along the way....
RoadDick
Re: Shift Problems
Thats the only thing I can figure. I'm gonna tear it down completely tomorrow and see if theres some kind of issue in the lower cable or with the shift shaft. I picked up a lower cable today and if its something else, I'll have to pick that up after the holiday.
Thank god we have great beaches within reach.....and plenty of cold beer and bikinis! :eek::)
