Shift Rod Distance on Johnson 40 HP (1990)?
Angboater
Anyone happen to know what the correct distance is for setting the shift rod on a '90 40HP Johnson (J40EESR)?
Also, which gear it is supposed to be set in during setting up the distance...
Thanks in advance for any replies!
*Searched the forum and could not find any hits.
Re: Shift Rod Distance on Johnson 40 HP (1990)?
It is --------21and15/16 inches ----In nuetral.----Easy to find using google.-Sorry, you will have to convert that to metric.
Angboater
Thanks Racerone!!!
... I actually checked Google, where nothing was showing up!
However, since I am in Sweden, Google often prioritizes searches from within this country... Have to check my settings!
Thanks so Much!
