Shift Shaft on '98 20hp Mercury
Knot Working
First, I want to say thanks for all the help you guys have offered. I have read insightful information allowing a novice like myself to bring a motor with frozen pistons back to life. Long story short, after putting her all back together- she started on the first try! Problem is after putting her in the water for my first test drive, I was shocked to find that she would only go in reverse. Again, after reading informative post of others making the same mistake, I realized that I probably did not have lower unit and upper in the same gear after changing water pump.
My question is, how can I get the units to the same gear on this model?
Thanks in advance.
Murray-
Re: Shift Shaft on '98 20hp Mercury
Pull it back apart,.......
Shift the controller to Forward,......
Shift the Lowerunit to Forward,+ Hold it There,....
(I use a bungee cord, from the cav. plate, around the propshaft,+ back to the cav. plate, to keep pressure on the gears)
Then Reinstall the lowerunit.......
Knot Working
Thanks Bondo,
Took 20 minutes and worked perfectly!! Thanks for the quick response which allowed me and the wife to have a great day on the water.
Murray-
