Shorelandr trailer for Sugar Sand boat?
sjbs
I bought a 1999 Sugar Sand Heat jet boat and I believe it is on a Shorelandr trailer.The ID number has faded away on the frame of the trailer. I need new u bolts for the leaf springs and Shorelandr can not help me with out that number to look up the part.If someone has a Sugar Sand sitting on Shorelandr trailer and you can read the ID number let me know.The u bolts are 1 3/4" inside by 2" high by 3/8" maybe 5/16".They are almost rusted through.Thanks, Steve.
Re: Shorelandr trailer for Sugar Sand boat?
You don't need to by them from Shorelandr trailer. You have the dimensions, just go an auto parts, hardware, trailer parts store or on line at a place like McMaster Carr and order them. To get the bolt diameter just measure the outside edge of the bolt. If the U-bolt is 2 inch and you can only find 2 1/2, OK that will work, cut off after you get the nuts on if needed.
sixfigures
Yes what he said haaa, one would think that having the dimensions someone at shorelander would have made a sale geeee, heck you can buy galvanized u bolts at any trailer supply place like previously mentioned or get stainless bolts from a fastener supply place . while you are at it check the bearings, springs , lugs and lug nuts the front coupler and check for any hidden rust if you have tubing that can rust from the inside out.
