Should Gluvit be on my Long list of things to buy
deerslayer303
Ok can someone give me the rundown on this Gluvit, I have read most of you speak highly of it, I'm just wondering is it something I need.
Thanks Again,
Shawn
Re: Should Gluvit be on my Long list of things to buy
Here is the list of Guvit FAQ from the marinetex web site.... If you are dealing with an aluminum boat that may leak.... yes.
Why is the resin can of Gluvit only partially full?
Materials are packaged in our facility by weight (ex. 2 lb or 8 lb.) All Gluvit containers are slack-filled (they are not full.) This leaves enough room for a power mixer to blend the resin and hardener entirely in one can.
Can I use a pigment in the Gluvit?
Yes, any type of epoxy-friendly pigment is recommended. It will be tinted, no dark color will be achieved. (Fibre-Glass Evercoat's pigments work well.) Do not use more than 5% pigment per total volume of epoxy.
What is the proper procedure for overcoating Gluvit?
To overcoat Gluvit after cure, wash the surface with warm soapy water or a dilute vinegar solution and a fine abrasive pad, or wet sand, then dry with clean towels or cloth. Frost-sand surface with 80-100 grit sand paper to remove any gloss.
What type of paint should be used to overcoat Gluvit?
Gluvit can be overcoated with any marine paint or other coating compatible with epoxies. Check with your paint supplier and make sure the coating you are using is epoxy friendly and suitable for your application.
What will happen if the Gluvit is not overcoated?
UV rays can deteriorate the epoxy, it will chalk (get cloudy) and possible crack over time. If there is no exposure to sunlight (ex. bottom of boat), there is no problem.
What is Gluvit?s pot life?
Depends on temperature 60 minutes at 72?F.
Can Gluvit be thinned?
Yes, Toluene, Xylene, Xylol, or Lacquer thinner in small amounts (no more than 5%.)
Can I use Gluvit to coat the inside of my gas tank?
No, Gluvit is not resistant to gasoline.
Gluvit can be used to protect the outside of an aluminum gas tank. Gluvit is an excellent barrier coat system that encapsulates the metal to protect against corrosion and pitting.
Can I renew and seal soft or rotted wood with Gluvit?
Dry rot is a common problem on boats with wood cabins. Gluvit? can help to restore damaged wood and seal it against further deterioration. Gluvit has a long ?open time? that allows it to penetrate deep into porous or rotted wood.
Drill small holes in the damaged area and fill with Gluvit. It will be absorbed by the wood and its hard protective coating will seal against further attack by vermin or weathering.
Gluvit?s protective waterproof coating strengthens stringers, decking and molding, and it flexes with hull movements to maintain effective bridging. It also seals cracks, chips, pinholes, leaky seams and rivets.
What color is Gluvit?
Gluvit is similar to amber in color.
What is the consistency of Gluvit?
Gluvit is the consistency of paint. It is easily applied with a brush or roller.
Is Gluvit rated for potable water repairs?
No, Gluvit is not rated for potable water repairs.
Can I use Gluvit on concrete?
Yes, Gluvit performs well on properly prepared concrete. Make sure the concrete is fully cured and free of any contaminates including dust, dirt, grease, oil, etc. Apply the Gluvit with a roller or brush and allow to fully cure. Any areas exposed to direct sunlight should be overcoated with an epoxy friendly coating after full cure.
03vrod
There is another product called Coat-it.Check the drift boat web sites and see what they say.It's about half the cost and the drift boat guys are switching to it and say that it lasts longer and is easier to redo when necessary.I just used it but haven't finished the restoration yet.I'm a diesel mechanic so I'm not trying to sell this stuff just tell you what I found during my search.Good Luck
Hermyboy3000
03vrod - can you post a link to the site? Thanks!
03vrod
the site I ordered mine from was GlazeCoat.com and just click on the coat-it container the gallon container [not full ] they sell it by the pound like Gluvit was 45 dollars.I know some people might think I'm crazy but I used 3 containers and did the inside and the bottom.My neighbor helped [he just wanted to We're layed off Truck builders ]I am very pleased with the results but will monitor and report back over the long haul.Like I said earlier check out the Drift Boat sites and read what they have to say.Good luckand happy restoring
I read those posts. It is designed to help boats take abrasion hits over rough surfaces. A few people had mentioned how it was easy to re-coat when worn. Guvit is usually only applied to seams and rivets..... not meant to be a full coating.
If you ever need anything welded you will occupy hours to remove that stuff if you coated everything.
Let us know how it works out. I will not endorse it because I never tried it. BTW coat-it is made by GOOP.
03vrod
check out ifish.net forums for some people who have experience with coat-it .Some people like it and some didn't as Bob stated it is used by many as a bottom coating to protect the bottom but it also seals like Gluvit unlike Gluvit it has fillers such as kevlar,graphite and ceramics.Maybe that's why it's half the cost.To my disappointment the 1 gallon container is only 3/4 full ,like Gluvit they sell it by the pound.I forgot to mention my boat is almost fifty years old and I wanted as much protection for the old girl as possible.I believe if you heat it a little it comes off pretty easy the same with most 2part epoxies.The west system recomends you heat there's when repairing leaks around rivets to help it flow.It's worth checking around you may find a equivalent product or a better price.Coat-it is pretty thick when you apply it but it flows.I had several runs that I sanded out and some down the sides which I took off with the wire wheel I used to strip the boat to begin with.Good luck and I hope for all the flack I got for mentioning this it helps someone.
