should i be concerned
scottn83
Should i worry if i drop the oil pan and find this :facepalm:
I think this was caused by my timing way to far advance cause i am a dumb *****
What do you think freshly rebuild motor
Re: should i be concerned
Not a problem at all, just run some seafoam through it, that's what everyone seems to think fixes all engine problems.
Ryanlewis2010
That might be the first time where don suggested something that probably wont work but hey then again you never know till ya try:)
Were there more than just the one piston in the pan?
oldsub86
:DGee, I'm really happy to hear that. I just bought a can this evening and have yet to use it.
Randy (who has a rototiller that won't run without keeping the choke partly on and hopes this stuff will help clean the carb out a bit)
Augie56
Follow up the SeaFoam with MMO (Marvel Mystery Oil) and you;'ll be good as new.:D
(((Sarcasm intended)))
Oshkosh1
Ensign
Nothing a can of Engine RESTORE can't fix!:facepalm:
Compression will be good as new!
jopes
Remove one from the other side so the engine maintains balance if it was a 350, and if it was just think of the fuel saving benefits because you will now have a 4.3L
MarkSee
Slather the JBWELD all over and the piston will be lovin' ya for it.:rolleyes:
30 Commander
Good thing you got the piston out of the pan....it could have blocked the oil pickup and did some real damage!
scottn83
Ok I got the sea foam the mmo the jb weld and engine restore non of these awesome products helped. In all seriousness will the 3.0 run 180 out enough that i can get to motor down the lake but pinging like hell. I know i should have stopped as soon as the pinging started but i didnt. I expected more power had to get my 20 yr old son to sit in the bow of the boat to get on plane. It is a 17 ft run about thought a fresh new motor should be stronger than that. Just trying to get an idea what i screwed up so i dont repeat this mishap
