Should I replace it?
krobbins
I am changing my drive cable and was wondering if i can just slide the new inner core cable inside and leave the old outer sheath cable in place?
Re: Should I replace it?
NO, no matter what you might be working on.
Ayuh,.... It's usually the Outer with the Groove worn into it.... The Inners are usually just Fine...
