Should warning light up, when pulling the engine?
Vandkanten
I have a Evinrude 35 HP 3cyl from 1997 model E35KLEUR.
My question is, does anyone know how the warning LED (located right at the rope pull) works ?
Should it light up when pulling the rope/cranking the engine? And then goes off when the engine runs?
Or do I have have an error that I have to fix first (since it lights when pulling)?
I can't start the engine yet, so I dont know if it will light off automatically after a while.
Is the warning light for low oil in the tank ?----And what model 9.9 ------" does the same thing "
Vandkanten
Yes, it is warning light for oil and maybe overheat too (wires are connected)
My model is a 35 HP 3 cyl from 98 or 99
