skeg guard for 25hp Merc
erniegator1
I broke off a good chunk of my skeg over the weekend. I cant seem to find a skeg guard to fit it (25 hp merc). Anyone have an idea as to where I can find one?
Thanks
Thanks
I would take it to a welding shop or prop shop and ask if they can weld a new one on
Fun Times
What year is the engine? You might want to try browsing the 2 following sites, http://www.firstchoicemarine.com/p-...ury-marine-18-25-hp-earlier-models-s-m12.aspx
http://skegdepot.com/products/skegs.html
Or like mentioned by AllDodge, a good aluminum welder should be able to get you back in shape. A prop shop would be best though as they usually are already set up to repair the skeg correctly along with already knowing what the "shape" the skeg should be to turn out the best looking.
Hope this helps some, good luck.
