slight hesitation on merc 115
BOAT DOCTOR
i recently purchase a 16ft champion bass boat with a 115 merc 98 i think. its the 4 cyclinder that idles on 2 cyclinders.the problem is when accerating at about 3000 rpm it hits a flat spot for a sec than kicks in a runs great after that.that flat spot is always there. went threw carbs a number of times and found nothing to be wrong.is this just a trait of that style motor r is there a fix.r is they a way to make motor hit on all 4 at ilde by maybe replacing carbs with air mixtures srews stump can anyone point me in a direction on fixing this problem r something im going to have to live with
1nebel0
Re: slight hesitation on merc 115
The adjustment of the acelerator pump is very important during the transition....motor works perfectly if adjusted correctly...many people have problems with this motor due to improper setup...
BOAT DOCTOR
would bye any chance anyone knows the procedure to setting the accelerator pump
mr 88
Try using the search icon located on this page,, Timing and Sync of merc inline 6,,, posted 9/24 04 by clams canino
