Slow speed @ Full Throttle.
hvluve
Can someone tell me what is the issue with my Motor? Only going 5mph at full throttle???
Boat Start Up Easy Every Time.
Did a compressor check and getting 120 PSI on each cylinder.
Any help would be great!! Thanks
Re: 1991 - 70HP Mercury Force Outboard Motor - Going 5mph @ Full Throttle.
Spark on all 3 ?
Does it rev up as it should?
What are your full throttle rpm's ?
hvluve
Re
Re
Thanks roscoe for replying. I'm a little new to boat motor therefore the only thing I know how to check is a compressor test.
It does go to rev but very slow at full power, same as forward.
I didn't do a spark and rpm's test b/c I do not know how. If you can give me a little tip on how to check for those I really appreciated.
Thanks.
