Small leak from raw water pump housing
mikeauton
Hi all,
I have just noticed that the raw water pump on my Volvo Penta GL-H has a slight leak coming from the bottom, it is spitting up on the belt with the engine running and this is how I spotted it. I tightened all 4 bolts, so I am confident this is not the issue, not checked the oring yet but about to go and pull this out just to be sure, though I doubt this is the problem.
Just been told by my local parts store that I need a new pump - $400 :blue: I dont dis trust them at all, but just would welcome some input from others before I go and commit some $$$ to this. Also looks like a not so fun job to fit the new one - seems the whole assembly needs to be removed behind the pulley wheel not just the housing?
They said it is a common problem on a 7 year old (260 hrs) engine?
skydiveD30571
Re: Small leak from raw water pump housing
Make sure you didn't double up the o-rings. A lot of people take the pump off and don't see the o-ring so they add another one and put the pump back on. The o-ring sits in a groove on the shaft and is hard to see without a mirror. Two o-rings will make the pump leak.
mikeauton
Thanks for the tip, I will double check but I am pretty sure I took the old one out when I last replaced it. Also the leak has only just come about since I last took the boat out.
As you seem to have the same engine, have you replaced your raw water pump? It is a $400 part!! So I am checking everything very carefully before I get my wallet out.....
skydiveD30571
No I have never had any problems with my water pump. I seem to remember that the commonly bad pumps were the old plastic ones but I'm not sure about that. I seem to remember a small leak several years ago, but after replacing the impeller it was gone. Definitely check the o-ring, the impeller being fully seated in the pump (I believe it should sit even with the inside lip of the pump), and then the tightness of the 4 bolts. I just can't see how these metal pumps can "go bad."
mikeauton
The dealer is telling me that they tend go at about 250 hours (I have 260 hrs on my engine). I also am thinking this is a metal pump with a brass housing - what is there to fail here?
There are a good few postings on this site reporting precisely the same problem, one with Don S (god rest his soul) saying "Replace the pump!!"
I also note your location, assuming you are only using your boat in fresh water? Possibly the salt just wrecks these pumps? Though I flush my engine really well after each use.
How many hours do you have on your engine? I am going to pop out to the boat later and have another play - will report back on any significant findings.
skydiveD30571
I wish I could say for sure, but I cannot. Previous owner didn't have an hour meter, and I added perfect pass last fall so I only have a guess. I believe I've put ~100-150 hrs on it in my 3 years, but no idea what the previous owner did the prior 4 years. Let us know what you find, it could come in handy in the near future for me as well.
mikeauton
I am doing a little research here and from what I can see, these things are definitely serviceable. Once the pump is removed, there is a seal on the shaft which I strongly suspect is what is causing the leak. It seems to me, you can pay your $400 for a new pump, but what you are really paying for is the new seal, bearing and possibly a new impeller (which I dont need).
Here is a little video which is very informative :-
2004 Volvo Raw Water Pump 5.7 - YouTube
I am going to pull mine out and have a closer look at it. Bottom line is that all these pumps will eventually leak, I suspect in fresh water you naturally get a longer life.
Here is a guy selling a service kit on ebay :-
Crank Mounted Volvo Penta Raw Water Pump Rebuild Repair Rebuilt Kit Sea Fresh | eBay
Will update when I know a little more.....
mikeauton
Here is an earlier thread from the forum which gives you step by step instructions, 100% confirmed there is no need to buy a new pump :)
My bearing is just fine, already removed the shaft seal and will order a new one tomorrow - $4 vs $400 for a new pump. If it does not work for any reason, I can always go buy the replacement pump.
http://forums.iboats.com/volvo-pent...ives/volvo-penta-raw-water-pump-625155-3.html
dannys2004glastron175mx
I rebuilt my pump the seal that you need its 16X28X7 and the bearing is a 6006-2RS, you will need a small 3 jaw puller to pull the hub off to get at the bearing
mikeauton
Hi Danny,
Thanks for your input, nice to hear you rebuilt your pump with no issues. I did already order the new seal, I have checked the bearings and they do not need replacing at this stage.
I have to say, it is a little annoying that the parts people and Volvo themselves try to sell you a complete pump - it is crazy when you see how easy it is to replace the shaft seal!! I am sure the bearings would take a little more work, but again not that difficult with even basic skills.
skydiveD30571
Hi Danny,
As much as I like my Volvo, this really drives me nuts sometimes. Last week I was having trim pump issues, and after further investigating I realized they will not sell just the pump, but you have to buy the pump/cover/lines together for the sx-a drives. $900 vs what is probably a $400 pump.
Hi Danny,
I got a spare seal and bearing in my tool box , so next time I need it I will have one on hand, you should do the same :)
dizzy1
My 2007 boat i got last year had the same exactly motor, got it from a bank repo. Had a slight leak from the water pump as well, maybe 10-15 drops per minute. I tightened the 4 bolts as well and nothing seemed to help. This off season, i pulled it apart and cleaned up the mating surface when changing the impellor. Also used a thick grease i had for orings(from a water softner on my house) to the main oring and bolted everything back together. Been out 3 times this year and not a single drop of water. Almost thinking you can get a leak around the oring if the mating surface is not clean or little dirty/rusty. Might be something to look at.
dypcdiver
Chances are that after the seal leaked it would allow water into the bearing, they are "sealed" but not watertight. For what a new bearing costs it is well worth replacing it to save having to do it all again.
mikeauton
So here is my conclusion on this one. I bought a new shaft seal for a few $$ and fitted it fairly easily by putting a little oil on it, placing a large washer over the top, then gently tapped it into place. I checked the bearings, they were 100% OK (it is much more work to replace the bearings apparently). When I took the old seal out, it was a big mess and not surprised it was leaking. Yes, the bearings will have got some water in and in my case this is salt water, but I flushed them out and oiled them up - I doubt they will go in the near future. I have just run the engine and the leak is gone for sure.
What I learned from this experience :-
1. The pumps do have a limited life, no doubt they last longer in fresh water. 250 hrs seems to be the point of failure for most folks.
2. You definitely do not need to buy a new pump!!!
3. This forum is awesome and it has saved me a lot of money already
4. Apply a little patience and think carefully about everything you do and most things can be fixed
So Volvo and my local parts store were more than happy to tell me I needed a $400 + tax replacement pump, I strongly suspect that they know only too well that you can replace both the bearings and seal - welcome to capitalism.
Imagine the cost if I had a mechanic look at this for me?
