Smartcraft alarm
walleye seeker
Last year i installed all new smartcraft gauges on my 350 mag mpi. Everything works great except i get a written alarm / horn when i turn on my key and My speedo that says alarm when cleared wont come back on until i turn the key off and back on. I need the audible buzzer or alarm that works with the smartcraft gauges but cant seem to figure out what i need.
Parts installed were
Tach with troll and readout
Speedo with troll and readout
trim
fuel
oil
temp
voltage
Fun Times
Re: Smartcraft alarm
Have you tried a master reset?
Also are you looking for a part number for the warning horn? If so I believe I found it.
Part number (816492A9) HORN KIT $44.17
Part number (816492A1) ALARM Accessory horn. $37.92
Type these numbers at the link below.
http://www.mercruiserparts.com/partsByNumber.asp
Do you have a smartcraft service manual?
Also Google smartcraft there is a lot of info out there about it.
http://www.google.com/search?source...ADRA_enUS351US351&q=smartcraft+wiring+diagram
Also the club sea ray forum guys are pretty good about using smartcraft.
walleye seeker
Yes i was looking for the part # for the warning horn which i have installed now but i still get the message fault horn on my tach. when the fault pops up about 10 seconds after i turn the key on i dont even have to start the boat the horn beeps once and the fault alarm message comes up. which is suppose to mean the horn isnt working but it is since it beeps.:(:(
