Smoked Salmon
Fishing Dude too
I was wondering if anyone had a recipe to smoke salmon that they would be willing to share.
JB
Re: Smoked Salmon
I smoke salmon in my Cameron's stove top smoker, though I doubt that's what you want to do.
I marinate a slab in 50-50 Teriyaki and Worcestershire for a couple hours and smoke it in alder on medium heat for about 20-25 minutes.
To kill for. :)
Bronlonius
Re: Smoked Salmon
48 hours in the smoker with very low heat.
Wow, that's a long time for salmon. What temp does your smoker have near the fish?
kenmyfam
Re: Smoked Salmon
Going to watch this thread with great interest as I would like to try some of these as well.
Just love smoked salmon.
rbh
Re: Smoked Salmon
I borrowed this from another site, we usualy get the sweat sticky style pacific species salmon around here, although there is the tougher jerky style some people do, or the plank salmon done on the BBQ.
Traditionally Indian Candy is hot smoked. I prefer mine smoked at a lower temperature. I also prefer to dry brine my fish. It is more time consuming, but the effort is well worth it. The same dry cure can be used to make awesome fish jerky, with a few modifications. Try my recipe and see if you agree.
Mix a 1kg bag of Rogers Demerara or Rogers Best Brown sugar with 7/8 cup of coarse pickling salt. Buy 2 bags of brown sugar in case you need more mix. I have found the Rogers Best Brown sugar dissolves better when using dry brine, so I prefer it. Do not add more than 1 cup of salt, or result will be too salty.
I cut the Salmon several different ways for Indian Candy, try different methods to see which you prefer. It is much easier to cut the Salmon pieces while still partially frozen. De-bone and skin salmon, remove all dark meat before smoking. I cut some pieces into small nuggets approximately 1" in size. Other pieces I cut larger, usually 2" wide, 6" long and 1.5" thick. This brine also produces excellent salmon jerky. If you want to try some Salmon jerky, cut 2" wide, 6" long strips 1/4" thick. Do not use belly strips for jerky as it is too fatty.
Cover the bottom of 8"x 8" Tupperware container with 1/4 inch of salt/sugar mix. Put larger pieces on the bottom layer. Cover bottom layer with another 1/4 inch of brine mix. Continue layering Salmon and brine mix till all Salmon is covered. Place Salmon in refrigerator while brining process continues. The brine mix will quickly begin to draw liquid out of the Salmon. This will form a thick liquid brine that will cure the fish to a very firm consistency. Once the liquid has formed, spices and flavorings may be added to the brine. I usually add crushed fresh garlic (8 cloves), crushed peppercorns (small palm full), grated fresh ginger (2 tsp), grated zest of 1 orange, and half a teaspoon of hot red chili pepper flakes, 1/2 tsp cayenne. Extra flavorings are a matter of personal taste. Add as many or few of your favorite flavorings that you prefer. I also like to add about 4 oz of dark rum to the brine once the fish has already firmed up. Don't add large quantities of liquid flavorings. This will water down the brine or change the salt/sugar ratio. Soya sauce will make the brine more liquidy, as well as being high in salt content, so I wouldn't recommend it.
With experience you will be able to judge exactly when the fish is cured sufficiently. You should stir the fish every four hours or so, to ensure even brining. I prefer to leave the fish in the brine until the meat is well jelled. The meat should no longer be squishy, but you don't want it to get too hard. Very thin slices, such as jerky should be left in the brine approximately a day. Thicker slices should be left in brine for 2 days. Each piece may be ready at different times depending on thickness. Check regularly to ensure that pieces are not becoming over brined.
Once the fish has reached the desired consistency remove it from the brine. This is not a very salty brine, so you can leave the syrupy coating on. If you prefer, rinse lightly with water and place on racks to dry. I bought racks at a cooking supply store with small 1/2 inch grid that will hold the smallest pieces without falling through. I place the Salmon nuggets on these racks. Leave the fish to dry until nice glossy coating forms on the fish. This may take several hours, or if you have the room, place the fish on racks in the fridge until the evening. Sometimes I leave the racked fish to dry in the fridge for a full day after brining. This improves the finish as well as the taste of the smoked product in my opinion. Adds another day to the processing time, but I often do this if there is room in the fridge.
I don't like my fish hot smoked that often, so I will describe the process I use to smoke at a lower temperature. I use a big chief, which normally isn't that good for cold smoking. Follow my tips and you can still use an aluminum smoker to produce a cold smoke, as long as the outside temperature isn't too high.
Wait till after dinner when the temperature is beginning to drop. Plug in smoker, place racks of fish in smoker. Thickest pieces go on bottom rack, thinnest on top. You don't want to raise the temperature of the fish too quickly. Place an object the same height as the bottom of the smoker door in front of smoker. Prop the door to the smoker open at the bottom approximately 1 inch. This will ensure that the temperature of the fish rises slowly. Do not add any chips yet. Let the fish warm in smoker for an hour to an hour and a half. By now, if it's fall or winter the temperature outside should be getting cold. Now, fill the pan half full with Alder smoker chips and place in the smoker. You can close the smoker door fully now, and let the chips burn for an hour and a half to two hours. Don't put another half pan of chips in before an hour and a half. This is very important. Don't fill the chip pan more than half full, or refill too soon or the temperature will rise too high. If the temperature outside is freezing you don't have to worry as much about the smoker becoming too hot.
Three pans of smoker chips will probably be enough to smoke flavor most fish. More pans will give a darker finish to the fish, which is more eye appealing. Cherry wood is also good in addition to Alder chips for smoking. Overnight is usually sufficient to smoke most fish. Unfortunately, chips may need to be added during the wee hours of the morning to keep the temperature low. If further drying is necessary during daylight hours, use smoker chips sparingly. Using smoker chips during the day may result in the temperature rising too high. The smoking time required varies with the thickness of the fish and the degree of moisture the fish contained prior to smoking. The consistency and dryness of the smoked product is a matter of personal preference. Every one seems to prefer the consistency a little different. I prefer to smoke mine so that it is a little hard on the outside but still moist inside.
Jerky is the exception, you obviously want to dehydrate jerky much further. It would take a long time to dry jerky by my method. Therefore, a few modifications are necessary. If you prefer your jerky a little spicier, coat it with cracked pepper and cayenne before placing on the racks and smoking. Smoke the jerky overnight the same as outlined for the Indian Candy. In the morning the jerky should be considerably drier, but shouldn?t need any more smoke flavoring. To speed up the drying process, remove the jerky from the smoker and place in the oven. Turn on the oven to 150 degrees, but prop the door open an inch. Cook the jerky in the oven till it is almost as dry as you like. It will harden further when removed from the oven, so be careful not to dry too long. Fat will probably rise to the surface during the jerky drying process. Use a paper towel to absorb any fat accumulating on the jerky. The jerky should be dry on the surface to prevent spoilage. However, I don?t think spoilage will be a problem. My kids usually devour the jerky before it is a couple of days old.
Finishing Glaze for Indian Candy:
If you want a really sweet Indian Candy, glaze the salmon with the following syrup. Heat 4oz red wine and 4oz dark rum, in a sauce pan. Add 2cups brown sugar, 1cup honey, (or maple syrup), stir until dissolved. Freshly ground pepper or cayenne may be added if you prefer a little extra spiciness. Glaze may be brushed on several or more times during the smoking process. Alternately, you may remove salmon from smoker halfway through smoking and soak fish for several hours before resuming smoking. There is also another way to give the Salmon lover with a sweet tooth what they crave. Simply place the smoked Salmon into this syrup and leave it to absorb in the fridge. When you remove the smoked fish from this gooey syrup it will truly taste like Candy. if you pack the smoked Salmon in the finishing glaze after smoking don't leave it in more than a day unless you want to dry the Salmon a little more. The sugar content will suck more moisture out of the smoked fish even without the salt content. If the smoked Salmon has dried to the texture you prefer, but doesn't have as much smoke flavoring as you like. You can cheat and add "liquid smoke" to the finishing glaze. Liquid smoke is available in most large supermarkets. Add a little bit at a time, as it is quite concentrated. Soak smoked Salmon in smoke flavored finishing glaze for a day. This will give the Salmon a heavier smoked flavor without risking raising the temperature too high by smoking during the warm daylight hours. I don?t know how long this fish will keep when glazed like this. Once everyone tastes this Salmon you won?t be able to smoke it fast enough
Fishing Dude too
Re: Smoked Salmon
Thank you for the replies so far, will be a couple of weeks till I am ready to do this but have never done before, and never been a fan of smoked fish but still willing to try.
82rude
Re: Smoked Salmon
rbh is that similar to the hardy boys candied salmon from the big island.ive become addicted to that stuff ,every body loves it.
Re: Smoked Salmon
you need to decide if you want cured smoked fish, which will always be saltier from the curing salts, or cooked smoked fish, which can be seasoned or marinated without much salt, but will not have the shelf life of fully cured.
rbh
Re: Smoked Salmon
I bet the recipes are similar.
I have had the salmon you see done on the smoke racks from the side of the fraser river around lillooet, but thats just dry smoke for preservation.
Fleetwin
Re: Smoked Salmon
I do mine on a Komado Joe (Similar to Big Green Egg).
Simple recipe, as stated above:
-thin brine for a few hours.
-then-Teriyaki and Worchester marinade for an hour or so.
-Rub with salt/pepper and Honey.
A couple hours at about 150*.
If you don't like the sweet crust the honey leaves, you can leave that out. The honey leaves a nice blend of sweet/sour.
Cofe
Re: Smoked Salmon
It all depends on what type of smoker you have. What kind of smoker are you going to use to smoke this salmon, and is it a whole salmon, or pieces?
Cofe
Re: Smoked Salmon
Electric or side smoker as I have both, the fish can be how ever I decide.
The electric or the side smoker would work fine. A large smoker is required for a whole fish, and like bubba said it could be 8 hrs. smoke time.
My favorite way is to make portion sized pieces,two inch thick and boneless, then brine them in salt water in the fridge over night. Wash the pieces after brining, then put them on cedar wood planks. Sprinkle salmon sea food spice on them and smoke for 1 hr. Turn the pieces over on the wood planks and smoke them for another hr. The surface of the salmon will have a white milky looking stuff on it (salt and liquid) I usually take a towel and dab it off for a better appearance before serving. I like to use a combination of hickory and mesquite. Fruit wood smoking works well also. Wow this made me hungry.... Good luck.
Edit: The cedar wood planks give a slight cedar flavor. You can smoke the same method without the planks. Just place fish on individual pieces of tin foil with the edges bent up about a half inch to help hold in moisture.
kenmyfam
Re: Smoked Salmon
All good stuff so far. Going to be trying some of these during this camping season.
woodsyfeller
Re: Smoked Salmon
I also like to keep my brine simple
1 cup plain salt (no iodine) (pickling salt is good)
1 cup brown sugar
1 gallon water
boil and dissolve salt sugar in a quart of water
chill the remaining water in fridge or freezer just don't let it freeze
after salt and sugar is dissolved mix brine and chilled water together make sure mixture is cold before adding fish (,you don't want to be pre cooking salmon in hot/warm water )
pour mixture in a non metallic container add your fish (I leave the skin on because it makes it easier to handle and doesn't make a big old mess on smoker racks)
place in fridge and brine at least 8-12 hours I prefer to brine mine 16-24 hrs depending on thickness of the cuts
make sure cuts are fully submerged you can use a glass bowl or other item to help hold them down.
remove cuts and rinse them with fresh water to remove excess salt (a rinse and gentle rub with your hands is all you need)
set cuts out and let them dry they should have a glossy tacky look to them
place in smoker and dry until to your likeness (I usually smoke mine in big chief electric smoker 8-12 hours depending on cuts sizes and outdoor temps)
check every few hours after 4 hours and rotate racks as necessary (I usually keep the large cuts close to heating elements)
I like to use alder chips for my smoke (2-3 panfulls is plenty the smoke is just for the flavor)
1 other trick I use if I am processing several fish is to make a large batch of brine and use bags of ice instead of chilled water
1 7lb bag of ice is = 1 gallon of water and place in a cooler instead of fridge
because of the time for brining and smoking I prefer to make batches of 50lbs or more of salmon
the salt/water ratio is all you need to preserve the fish you can leave out the sugar ,you can experiment with different flavors some use worsterchire sauce, soy sauce ,honey, moleasses , ect .Just experemant and try different things
I used to do the dissolve salt till egg floats but always seemed like the end product was too salty . 1cup per gallon is what I've learned to work with.
Vacume seal and freeze what you don't eat right away or plan to eat in the next few days.
Cofe
Re: Smoked Salmon
I agree with woodsyfeller about the salt brine. I too use one cup salt to a gallon of water for a brine. Also I forgot to mention...Pat the fish dry with a towel before smoking.
woodsyfeller
Re: Smoked Salmon
Yes you can make salmon jerky in dehydrator. That is basically what your doing when cold smoking or using low temp. Brining is what basically chemically cooks the fish, the smoking just helps to remove the moisture even further adding flavor along with it. If you want to have that smoked flavor I would suggest using liquid smoke in the brining process.
This may gross some people out but true smoked salmon is basically uncooked fish with as much moisture removed as possible. Hence the low temps. I would imagine the native americans probally dried the flesh to jerky like consistency to help preserve the flesh for the long winters, that's not a proven fact or anything but just what I would imagine was done when trying to make something safe to eat after sitting for 4-6 months.
