Snaps for a Snap On Cover
Bulbash
I decided to give it a try and make a new snap on cover for my Bayliner Capri 1750. I have a good 30' roll of sunbrella material, however I do not have any snaps. All local stores do not carry anything that strong and durable. Does anyone know where I can order snaps + device to install them for a reasonable price. Thank you
Jeep Man
Being as you are in the GTA, I suggest you check at Fastenal or Bolts Plus. Failing that, check with your local boat top company and ask where they get theirs.
http://www.rochfordsupply.com/shop/F...%29/index.html
http://www.rochfordsupply.com/shop/F...uds/index.html
Make sure to select the Stainless ones.
Best to have the snaps reinforced with webbing or multiple layers of material.
I personally use this tool but it may be out of your budget:
http://www.rochfordsupply.com/shop/U...ner/index.html
It's the best and you will be cursing the hammer ones. Plus you can use this while the cover is on the boat.
Quick fit pins are also nice to have:
http://www.rochfordsupply.com/shop/B...ers/index.html
Tools can add up!
yep, need ^ that tool. using the little mandrel and a hammer sucks
dozerII
I agree you would have to fight pretty hard to get that tool out of my possession.
JASinIL2006
Have you ever used one of those? Not fun!
Yes, I bought a cockpit cover for my boat and had to install the snaps. I did have a fabric punch to make the holes in the Sunbrella and reinforcement webbing. Installing the snaps was really not that bad. Took a couple of hours. It wasn't difficult, it just took some time. Compared to grinding fiberglass,it was a breeze!
For the future, try using an old soldering iron when you do that. It melts the fabric and keeps it from possibly tearing later on down the line.
Duh,........ Absolutely Brilliant Bruce,.... Donno how I missed that one,......
I Used to have a decent snap kit, with the vise-grip based tool, 'n many punches for alota different fixtures,.....
And a huge bag of mixed every sorta fastener saved over a lifetime fixtures,....
Loaned it out, 'n don't exactly remember who,.... Where I thought it was, it weren't,.... :rolleyes:
I like the looks of the 1 ya linked to earlier,...
The straight clampin' action would be better than the straight jaw vise-grips,...
I have an old pencil tip soldering iron whose sole purpose in life is melting holes and cutting rope.
LOL...looks like they just welded on some dies. Of course the replacement dies for the press-n-snap are $40/set.
So what happens when you want to do eyelets and studs...buy another tool?
The one is the center is an eyelet and stud.
astor
2018's Starmada Splash Of The Year.
for the eyelets a kit like this with the dies for both looks like solution
Bulbash
Thank you guys for all help. All the links are very useful. Now I have to count number of snaps on the boat, figure out the size.
When measuring snaps, do I measure inside diameter, right?
In regards to the ebay tool, how is it vs hammer type? Much easier to work with?
Woodonglass
I think it is. Like Bruce says If it's on the boat it's the only way to go but even when it's on the big work table getting the anvil and everything lined up the hammer it in place is a pain. I think the tool is much easier and faster. More expensive but what's your time worth??
