So far so good
jitterbug127
2 things to report: The lithium starting battery I have used for the last 2 seasons has been perfect. My outboard is a 1980 35 HP tiller Johnson that only has the electric starter. Not the rectifier or stator so no charging available. I have run my fish finder and started off same 20 ah battery. Its been great.
I also had the motor mounts replaced on my outboard, and i have seen a 1.2 mph top speed improvement. I did not expect this. Motor looks more stable when I'm hauling it down the road too.
Yes but did you put the sheet ice racing blade on it yet? Lol....
Thanks for the report. New style batteries have come along way.
FishAtFive
I've had the same experience with my lithium starting battery*. It lasts days without needing to charge. Provides a steady current no matter if it's at 80% or 40%. Just flat. And I removed/disconnected the stator and rectifier so will never need to replace those parts. The only downside so far I have found with lithium is that some of the old electreonics cant handle it, like for example my massive 24 pound trolling motor that is almost 40 years old will blow a fuse if you run it on the highest speed for too long.
*Note: these are special "starter" LiFePO4 batteries, not just any lithium battery.
lots of comments about these batteries on ETEC technology.. BRP recommends lead acid or AGM
jitterbug127
Pardon my ignorance, what is an outboard motor mount?
They're are basically what holds the powerhead onto the midsection. They fail and there is a bunch of play in the powerhead. This can lead to decreased performance and in theory powerhead could be come detached. Idk how extreme motor mount failure can get, but I imagine horribly.
jitterbug127
Same i have a 20 ah starter LiFePO4 battery. Its been great. My 100 Ah trolling motor battery is doing great too.
Rubber motor mounts....I disagree with a power loss but the motor not shaking so bad is better which usually happens at idle speeds.
As you know those upper internal bolts that snap from abuse could definitely be catastrophic.
I usually just go with it on 50 year old motors.
Ok thanks i was thinking what bolted to the transom and could not picture it. Powerhead mounts.
jitterbug127
I think this will be the third season on my 35 hp. It runs great. I did turn the idle down as low as i could get it to be able to troll. Problem I ran into is its too low to start sometimes. having to take cowling off to adjust low speed needle Is my only complaint about this wonderful outboard.
You should adjust the idle at the timer screw located outside ....wait, is this a tiller?
Most folks with smaller outboards have not had any issues using these batteries for starting purposes from my research. You will find the most mfgrs do not recommend them for high HP motors as the draw is much higher. Can't recall anyone complaining about these batteries, unless the owner misused them or charged them improperly. Yes there is a flawed battery on occasion as with anything. I only use mine for my trolling motor, but it has exceeded my expectations in power and longevity. Unless you have a recently new trolling motor, the older motors can't handle the increased voltage of the LifePo4 batteries. While only 13.3 volts, up from 12.8v on a LA battery, running a motor at wot for a period of time will or can cause damage. Most electric trolling motor Myers have addressed this issue for the past few years. Anyone needing a new battery needs to look carefully at these LifePo4 batteries.
