So I became a proud boat owner today.
Remember, old boats take lots of cash to keep floating
Great boat to start with, being aluminum is even better !! Many fond memories from my old Islander, loved that boat....but, do to life changes had to downsize. Look forward to your rebuild pics.
Wmcdonald
Closed cooling on that OMC sterndrive.-----Inspect that drive carefully.-----They are not on top of the " hit parade " in many areas.----Picture of the ball gear wear ?
matt167
If you have to do the transom, it’s a perfect time to fill the big hole and do a switcheroo to Mercruiser. You can find a rotted 3.0L glasser and gain yourself 10hp without much issue. Some will say 4.3L but 2.5 and 3.0L is what StarCraft felt adequate with for years. Also the 4.3L is wider than StarCraft intended for the original seating in the rear. A few got an inline 6. If you were frugal you could find used mercruiser manifolds and parts to put on your OMC and then buy a transom assembly and lower unit. But cost may be similar to a rotted boat swap.
Wmcdonald
Those all sound like good options. Price is an issue.
Interesting Angle that the Fuel Tanks sits at. The Supply fitting is on the High side, and since the Pickup Tube, is likely straight, a fair bit of Liquid, be it gasoline any likely water, are never removed from the Tank
I imagine the Wood inside the Tubing that the Engine mounts to is rotted and also needs replacing
Keep in mind, that a Boat, is a Hole in the Water that you will be continuously pouring Money into. BOAT, is also Acronym for 'Break Out Another Thousand'
