Some opinions please.
Gosub
Hi guys,
My engine is a Merc 5.7 V8, not sure of the age but I think it is from about 2002. Yesterday it went very wrong. I had been tubing and skiing without any problems, everything worked as it should. After a 20 minute run at 3000 rpm we went into a cove and ran at idle speed for 10 minutes. We powered up and got on plane then it all went bad. The engind suddenly became noisy, like a bad deisel.
I powered down and switched off the engine. When I opened the engine cover to inspect, everything seemed OK. The engine was not overheating, it was touchable by hand. I tried a restart with the cover off and it sounded horrible so I switched off again.
I got a tow back to the marina where the mechanic inspected the engine and declared that the crankshaft was the problem. I was going to need a bottom end rebuild.
One experienced boater told me that he wouldn't rebuild the engine as it would throw the crankshaft again. He said once an engine does it, it will do it again. He said he would go for a short block as the cost of the short block would be about the same as the rebuild. I'm waiting for the estimate from the mechanic to do the comparison. If it's the same I would go for the short block, but I think it will be a bit cheaper to rebuild.
Can you advise me please? Any previous experiences I can draw on?
Cheers
Steve.
Re: Some opinions please.
Hi guys,
Cheers
Steve.
Ayuh,.... I think you'll find replacin' the Long Block is the Cheapest, Easiest, Quickest way to fix it, 'n get back to Boatin'....
Gosub
OK I have the estimate. The short block option is twice the cost of the repair option. The long block price is three times the cost of repair. :eek:
SeadawgVB
Notice his location! May have something to do with the pricing.
Gosub
Yeah Seadawg... I get screwed for everything to do with the boat. Scrub that, I get screwed for everything period. :redface:
makonnen
I'm sure this might spur a debate...
Get a short block from a GM dealer - its way cheaper than a marine one and all the parts are NEW and not remanufactured. Convert it to marine (change frost plugs to brass and water pump)
Fishermark
Normally I would agree - or actually go with the complete engine from GM.... however, with the original poster in Spain that is apparently not a viable option.
I would suggest getting a second opinion before rebuilding the engine.
And the idea that once an engine has a problem with a crankshaft it cannot be successfully rebuilt is simply not true.
