spacer location
barnyard
reinstalling SBC into larson 23'. does spacer install above or below transom plate?
Bt Doctur
Really have to give us more info ,Didi you replace the rear motor mounts?
Did you loosen and free up the front adjusters?
Bondo, wasnt there a post by the late Don S about first timers posting something
Ayuh,....... Lotsa great info was lost when Don passed,.....
Everything in his Adults Only section was lost,.....
barnyard
there is a spacer (coller ) about 3/4 thick that goes thru rear engine bell housing to transom mount , one on each side Rear motor mounts
I assume you are talking about C in the pic in this thread ?
if you have the older style with the springs that is a different animal but as mentioned above helps folks to know what you are working on
Also as BT suggested loosen the front mount - easier if you have crows foot socket to adjust (depending on engine compartment)
barnyard
thanks Scott.exatally what I was looking for. also thanks to other replies
