Spark Knock...
Four86Winns
After my Mercruiser 140 overheated (bad impeller) it developed a spark knock that goes away only when the timing is backed off to about 4 degrees ATDC.
Of course I know that the normal timing for this motor is 6 degrees.
Any ideas on how to solve this problem?
Thank you so much for your time, yall have helped a lot in the past.
JustJason
Re: Spark Knock...
keep the 6 and run higher octane.....
whats the compression at?
Four86Winns
Re: Spark Knock...
I haven't checked since before the problem; and compression was definitely where it should be. I know I have compression in all 4 cylinders, just not sure now much. I probably should get on that.
