Spark plug cross reference question
texsun
I am replacing the OEM spark plugs on my 2005 Volvo Penta 5.0 GL-E. I wanted to use NGK ...but I'm having a difficult time finding the proper plug. The Volvo Part number 'seems' to be 3861632...but my confidence is not high.
Can anyone please assist with the NGK plug number?
Thanks in Advance!
Pretty sure your motor takes the ac delco MR43LTS spark plug. Not sure what it crosses to ngk
If you post a serial/model number folks here have access to volvo info and can steer you right
texsun
Thanks for the replies!
Here's the Model / Serial number(s) off the side of the air filter cover.
Also, I'll be OK with the AC Delco MR43LTS....if that's the best replacement...just let me know.
I have the owners manual...but it only gave a Volvo Part number.
5.0 GL-E
3869254
4012146313
Thanks Again!
Mark
5.0 GL-E
3869254
4012146313
Thanks Again!
Mark
Ayuh,....., The ACs are an alloy body, rather than plated steel,...... less apt to rust, 'n corrode,.....
