Specific winterizing questions 5.7 GSI/ DP-A
bransjeep
this is my first time winterizing this boat so im just looking for assurance that im doing it right..so far i have treated the fuel system, fogged the motor, drained the manifolds, disconnected my raw water pump( Engine is closed cooled) used compressed air to blow out the remaining water in the lines, (some did come out), them bumped the motor for a quick second or two for the impellor to purge the water intake line. removed batteries and placed them on a trickle charge. my outdrive is off for this winter as i am replacing the suspension fork come spring time. engine oil/filter has been changed as wel as the fuel filter. anything else that should be done to prevent freezing? thanks in advance guys
Re: Specific winterizing questions 5.7 GSI/ DP-A
Ayuh,.... Did ya drain the raw water side of the heat exchanger,..??
