Specs for Older GM Marine Engines
83Evinrude
Re: Specs for Older GM Marine Engines
I'm curious to see how my '04 5.0L
Ayuh,... Your motor is virtually Unchanged, compared to the links you posted...
83Evinrude
On some features such as roller cam, heads etc. that may be true. Mine has a 2bbl carb though instead of FI so has 220hp vs 253hp for the current version, not sure what the torque difference is since I have no spec from GM or Volvo.
Ayuh,... Maybe if you stated your ultimate Goal, somebody could Help...
