Speedo Stopped working
Zigo
Anyone else have this? Its not a big deal but I'd love to fix it.
Its a 2013 q5 SF
Re: Speedo Stopped working
Yes, please go ahead and fix it . . .
Check for a pitot tube on the leading edge of the outdrive . . . probably clogged.
PrinceValium
As Tpenfield humorously stated...The speedometer pickup for these boats is on the leading edge of the outdrive. (there is no pilot tube sticking out like on other boats) I just had the same issue and had to blast it out with compressed air earlier (the Sacramento river is relentless on debris floating down the river).
Here is a pic of the outdrive edge...you can see the opening:
Here is a pic of the camlock style tubing for the speedometer:
Push the grey button and you can lift the tubing off:
I used some drip line with a fitting on the end to slide into the opening and used the compressed air to blow it out...whatever was in there popped out pretty quickly from the opening on the outdrive. Make sure you do not try to clear it from the outdrive edge up as this would only force the obstruction further up:
Hope this helps!;)
whitey224
If it is a 2013 I would take it back to the dealer. It is probably plugged but there could be something wrong so it might be better for them to look at it.
Zigo
Thanks for the great pictures! Ill give that a shot!
Zigo
We tried but still no luck, I"ll look at it more next year. So far the boat is winterized and in the garage for the winter.
Much to busy fishing and wakeboarding to care about the speedo! Hehehe
Mordekai
I had to use a drill while running it in reverse to clear mine out.
Ended up was a chunk of wood in there.
