Speedometer pickup in outdrive, not working
Status
Not open for further replies.
1CoeRay77
It is not clogged with anything. I can spray water into the holes and the water comes out around the plastic coupler where the air tube connects to the outdrive. Would this be a simple fix by opening up the lower unit or should this be left for the professionals.
cannonford57
Re: Speedometer pickup in outdrive, not working
take the line loose at the back of the speedo,blow air through it to see if its clear...
jerryjerry05
A hose or a piece of weedeater line in the hole.J
TilliamWe
Banned
Your fitting in the front of the anti-ventilation plate is either loose or broken. It's a strictly external repair. Tilt the drive up all the way, and lay down in front of the drive. Remove that front anode to see better. Then you will see the fitting with the hose attached. It's a "twist and lock" kind of thing. Sometimes they untwist and fall out. Other times, guys forget about them when removing the drive and PULL HARD, and break them off.
Does this photo help at all?
1CoeRay77
The speedo works when I blow air through the tube. When I put water to the holes on the lower unit it comes out around the fitting where the tube connects. That is telling me something is broke or has come disconnected inside the lower unit.
Might help if you posted what drive you have and maybe even the year.
TilliamWe
Banned
There is nothing inside the drive. Just a cavity.
You may just have a faulty connector for the speedometer where the hose connects to the drive.
Just order a new connector assembly from your Mercruiser dealer, about 10 bucks. PN 815956A1
The above is for this type connector.
attachment.php
1CoeRay77
Don, that is it. The fitting that screws into the lower unit, water is coming out around that fitting and not through it. And I just noticed a screw in the hole for the pickup on the starboard side the lower unit while I was trying to clean it out again. I suppose that could mean something.
TilliamWe
Banned
Speedo pickup hole in the starboard side? Can anyone confirm that? On Bravos the hole is in the leading edge of the drive. Not on one side or the other. Is an Alpha different?
There is only one speedometer pickup hole, and that is on the leading edge of the lower unit not the side. Not sure what you have that has a screw in it, could you post a picture?
My guess is the lower piece of the connector is cracked and that is why it's leaking. Just replace it, for 10 bucks it's an easy and cheap fix.
1CoeRay77
Im an IDIOT. Got the right hole cleaned out this time, it was pack full of black soot I didnt even hardly see it.
It works great, it is right there with the speed on my garmin.
Thanks for all the help.
mnypitboat
I just searched and found this thread. Glad you got yours fixed. Mine is clean, but I have not gone any further than the outdrive.
Does that vacuum type line go all the way to the speedo? If so, can I just pull the end off up by the speedo and blow it out with canned air or something? Or do I need to use compressed air through a blower fitting?
TIA
John
Status
