speedometer pitot problem
strocker383ca
does someone know if they made aftermarket one .. at 60mph and more the pitot just flip up and no more speed on guage
5150abf
Re: speedometer pitot problem
I am sure they still make them and I am also sure they don't work, if you really want to know your speed get a GPS, they are always right and you may find your boat is alot faster/slower than you think.
The only one I have ever heard of anyone getting to be reliable are built into the outdrive.
Silvertip
Any store that sells boating/fishing equipment and supplies will have generic pitots. Whether or not it will stay down at those speeds is questionable. But they don't cost a fortune so just replace the one you have and give it a try. You would also epoxy the pitot joint so it can't pivot up. If it strikes something underway it will obviously break but again -- they are not expensive. With an engine that pushes a boat to 60+ MPH, there should be a pitot built into the lower unit on the engine.
arks
Yeah, Livorsi Marine sells a S/S kick-up tube and mount. It's good up to 80MPH.
I had one on my old Wellcraft and it worked fine.
Retail price $73.
I agree that a GPS speedo is a better and more accurate way to measure speed- if you can afford it!
Retail price $73.
$73 :eek: for a pitoh :eek: You can absolutely get an older GPS either re-furbed or ebay for that money;)
Gary H NC
For 11 bucks i would try the one i posted the link to...
