Spiral Cell Batteries worth it?
mls2002
Time to replace the trolling motor battery. Are Spiral cells worth the extra cash? Would I be better off to get a lead battery and an on board charger. Trolling motor is used all day when fishing. Boat is 16' Grumman V hull.
Re: Spiral Cell Batteries worth it?
"I" think that a Quality Name Brand Marine Deep-cycle is Plenty Tough Enough..... Then you can spend the change on Baits,+ Fuel,+ Beers......<br />I've had Excellent Luck with Excide, or Diehard, or Interstate.......
snapperbait
I'm with Bondo on this one... Unless your fishing every day and need fast recharge times, I'd stick with the lead/acid deep cycle batts...<br /><br />Wal-mart Everstart batterys have done good for me..
93evinrude
I'd go with lead-acid and an onboard charger.
