Sportcraft tri-hull rebuild
a1964rn
Re: Sportcraft tri-hull rebuild
I used my Kubota tractor when flipping my hull. I screwed some 12' 2x6's to the side of a pallet to move it around on. after I got it flipped. I had to move mine into/out of my garage long ways, so I couldn't pick it up by the side.
madman960
Jim,
Nice progress so far. I do not have access to a fork lift but I do have a few home built toys. I will post pics when I use them.
Bill
eaglejim
Thanks for the quick reply's guys I thought I had read it somewhere just needed to double check will post some pics later on. Jim
eaglejim
Well here are some pics of the deck and transom
We still need to glue the transom together it wasn't the best of weather
electric603
Looking good eaglejim. I can't wait until I'm at that stage. It will be late spring by the time I get there.
tallcanadian
Isn't it nice to see all that new wood sitting there? If that don't get ya going, nothing will. :D:D. You can actually put the transom together now. Just a couple tubes of PL Premium and some gyproc screws and you can glue that puppy together in no time.
eaglejim
What is PL Premium?and where would I pick it up at, I looked into a adhesive called cx-948 it also comes in tubes super strong won't come apart,and it is nice to get back to working on the boat,I will need a lot of help on fiberglass did a little about 45 years ago with my grandfather but that is about it.Next on list is glue transom together and fix the 2 slices I put in the boat taking out the old deck.Thanks Jim
eaglejim
Thanks,They didn't change much in the way they built them from "72" to "77"
tallcanadian
PL is construction glue. I use it on my stuff. It bonds like steel. You can get it at any hardware store, I'm sure. I just sqeeze it out of the tube and spread it with a trowel to give the transom a nice even coat, then screw the two halves together. A lot will squeeze out on the edges. It will take a few days to harden. Then remove all the screws when your ready to glass.
jbcurt00
Comes in a few different types, is similar to Liquid Nails, and is found in the caulk aisle (near LiqNail) in the big box stores...
eaglejim
Thanks guys I am on it,going to hardware store today.
electric603
Yes, they look very similar, except there was no foam in mine. Not sure if it was built that way because the deck looked like it
had been replaced before.
Woodonglass
You are doing some outstanding fabrication on your deck and transom. What Resin are you planning on using? What did you use to Lam the 2 pieces for the transom?
eaglejim
On the resin question whatever you guys tell me to use,just got the loctite pl 400 ti laminate the two pieces together.I will probably do that tomorrow thanks Jim
eaglejim
Laminated the two pieces of the transom together
All screwed together
Woodonglass
Takes 72 hours for the PL to fully cure. Did you use a 1/4" trowel to spread it evenly? If it's been less than 2 hours I'd go ahead and use Deck Screws and place em about ever 6". Don't want any air pockets on the interior of the lam. You can remove the screws after it fully cures in 3 or 4 days. When you install it in the boat the resin will fill the screw holes so no problem there.
eaglejim
Well did it a little different,I did trowel it on and I did use deck screws except they are on the wood pieces acting like a vise and I am going to let it set for 3 days. I guess 2 out of 3 ain't bad (I think I can make a song out of that). I will need some input on fiberglass next so if you can give me a little notice so I know what to pick up and be able to do it right it will be appreciated.You guys make me look like I know what I am doing, Thanks again Jim
eaglejim
Happy New Year off to work on the boat
eaglejim
Well might get to work on the deck this weekend,1st question have two small slices (taken out old deck) what is the recommendation,2nd what kind of resin should I look for and what is the procedure or if any of you all have links that is good also, thanks Jim
jigngrub
How about some pics to show us where you're at on the project, and of the 2 small slices you speak of... I don't quite understand.
What are you going to be doing with the resin, laying glass or sealing?
