spotty sticky gel
sbooy42
So I gelled the bottom of a 26' Pursuit and there are a few spots that are sticky... the rest is all hard but a couple spots just aren't getting hard....its been two weeks..
We did go over a few prior repairs that were hard... Spectrum gel...cut with dura tec per directions....
Suggestions please and thank you
harleyman1975
Ensign
Only thing I can suggest is that it was not mixed thoroughly enough...Options are to leave it and see what happens or sand/remove defective areas and try to spot it in.
coat the area with PVA, if that doesnt harden it up, then you may have to start over.
sbooy42
it was PVA'd... tried heat lamps..etc Have wiped all sticky areas clean with acetone...back to square one..
Thanks for replies..
gel doesnt cure in heat, it cures in the absence of air. hence the need for a wax or PVA. if its still sticky and has a good layer of PVA, then it will need those areas re-gelled.
