Mr. Demeanor
iboats.com Partner
- Joined
- Mar 6, 2006
- Messages
- 55
This test was to see the effectiveness of using vinegar to remove salt and scale deposits from a marine engine.
I know there are effective salt removing products available. I chose vinegar for this test.
The test subject is a salt water used 1994 Yamaha 130 V4 with unknown history of maintenance until about 18 months ago. At that time I purchased the engine and have used it about 80% in salt and flushed thoroughly after every use. I recently ran the boat for about 50 miles in fresh water and then a nice salt water run about a week ago.
I filled a large heavy duty garbage can about 2/3 full with water and added 4 gallons of vinegar. The boat has a nosecone and uses a transom mounted water pickup so I disconnected the house, primed the pump, and dropped it into the water then lowered the lower unit as far as possible. You would likely just have to submerge your lower unit until the pickup grates are covered.
Yes, that is a little grass stuck in the t-stats. Last time out I ran through a lot of floating grass in Charlotte Harbor that gets pickup up by my transom mount pickup. I have since added a sea strainer.
These are pics of the test subject, thermostats, and housings prior to the test.
