Spring Is Coming
rocky100
Is there such a thing as de-winterizing?
I had my marina winterize my I/O (mercruiser 3.0)-what needs to be done to get the boat out to start using it in a couple of weeks? getting antsy, as if u couldn`t tell!lol;)
Re: Spring Is Coming
Ayuh,......
This thread Right Here will be pinned to the top of the forum,...Soon....
Yea, Bondo, it is getting close to cracked block season......... errrr, I mean spring.
There it is, stuck to the top again ............. a sure sign summer is close and the winterization thread is gone :D
Ayuh,........
I can't Wait,...... To be Ridiculed for Somebody Else's Incompetence.... :rolleyes: Again........
oops!
we got 8 or ten weeks to go......
still snowin daily.......avalanch season.......
but as far as bein ridiculed ....goes.....
have you ever put up a big sign that says ...."if you have a cracked block ......its your fault not mine"........?
Naw,....
A year or 2 ago, I forget his name, Took My advice,+ stored his motor using the Dry, No Antifreeze method.......
Trouble was,.... He Didn't Drain Everything...... He just Thought he did....
That spring,+ probably to this day, he rode Me Hard that it was My fault his block Split,+ he changed his signature to something like Mine,...
Except it said Antifreeze, where mine says Grease......
Which of course is a Blatant Lie,....
'cause alittle antifreeze is Worse than no antifreeze at all......
It's always the ones that either pull the thermostat housing and try to put antifreeze in on top of the water, without first draining the system, or the ones with a raw water cooled engine that try to just run it in thru the muffs.
Just watch, right around mid April the posts start coming in. Should have went ahead and saved all the 'Winterizing" threads where people that didn't know what they were doing decided the above two methods will work fine for them ..................... because it was easier than doing it properly.
Dshow
This was my second winterization... I did the anti-freeze thing, and then drained it after that. The strange thing was, a day or two later, I re-opened the drain plugs and a little liquid came out??? I'll keep my fingers crossed until I check it out in the spring...
erikgreen
Naw,....
Ok, I've gotta ask.. what did he miss?
I winterized my motor last year myself with help from the board, and I'm pretty sure I did it right, but there's always that nagging feeling......
What he missed, was the details. Anybody can pull a plug and put it back. Was the hole probed with a stiff wire or screw driver or something that would make sure it wasn't plugged with rust, crud, crap or corrosion? Probably not, plus some drain fittings don't make it possible.
A plain old pipe plug, and KNOWLEDGED of what you are trying to accomplish is all it takes.
If you don't have a clue what the draining process is doing to what part and what is involved with makeing sure it is drained, then you shouldn't be doing it.
I have said MANY times, take it to a dealer the first time, pay for the job and have them let you watch and explain it. Then you know how and WHY it was done that way.
90% of the people with cracked blocks have only themselves to blame because they did NOT know what or why they were doing anything.
Just that some book or some forum post that seemed easiest to do didn't work and now they have a dead engine.
Hate to be the one to tell you guys, but I have worked on a lot of different boats for many years. It's not easy. If it was, everyone would do it.
It's mostly hard, painful work. If you don't do it properly, get out your check book.
erikgreen
Well, it's too late for me to take it in.
I guess we'll see if I did it right in the spring... if you read painful posts from me here, you'll know what happened :)
Donno,.... He wouldn't say,....Other than it was My Fault....
bjcsc
I remember that, but also don't remember who it was. I also remember that he would take shots at you at any opportunity in other threads. At least he's gone...
Robj
Maybe April will be a good time for me to get a new project. For Sale, boat iin excellent condition, but has a cracked engine. There should be a few of those around.
Have a great day,
Rob.
FreeBeeTony
I'm just hoping for a trouble-free season as I'm sure we all are!
After the way my season ended last year...........I have baely looked at the boat since I put it away in October..........and that's odd for me..........I'm usually doing something to the boat during the winter.........this year I didn't do anything............so I decided to gut the kitchen and remodel...........what a mistake.......:)
Anyway.........I'm just going to de-winterize, check the bellows, paint the bottom, wax it and break-in the new longblock. (That will be another thread).
Good luck to all this year!
starsnstripers
SPRING? It's 18* here Brrr. I'm staying right here at the pc and make a plan of attack when the weather does break. Can't wait Got a bunch of parts for my engine/drive install. Need a few more things so i'm still shopping. SOON-SOON>:D (here) is Maine
oops!
its kinda lousy when people wont stand up and accept responcibility.....allways the blame game.....i been using the "dry" for years.....i know if its cracked in the spring......guess who didnt drain it..!
the weather here went up to +5 yesterday...aprox 40 degrees......man...felt like spring.....!
THE BEEF
I pump 5 gal of antifreeze thru my muffs after its up to temp for 10 min.
fog after 1 gal left.hope its all right.This year I will follow you advice on winterizing.
Beef
Fishermark
You guys are too funny! Why in the world anyone would CHOOSE to live where you have to winterize anything is beyond me. :) :D If you're ever in Southwest Florida, look me up! I'll be out boating. (When I'm not working of course ;) The bills have to be paid even here in paradise).
