Spring Shackle bolts
Clipper 800
1998 Bayliner 175 3.0 litre Bayliner trailer.
Got this boat and trailer used about a month ago. Both have been sitting for 8 years,in a barn covered and away from the weather.
Yesterday I pulled the bolts on the spring shackles and found a lot of corrosion , on the bolts and the bushings.
Previous owner had used Bostick Anti seize compound on the bolts, and the action of 2 dissimilar metals, and the water ,has caused the bolts to corrode.
This weekend I plan to repack, and inspect all bearings and replace the bolts and bushings on the spring shacles.
Any recomendations on the type of grease I should use for the bolts on the springs???.
Once this is done I can start on the boat and motor etc. Thanks in advance for your assistance. Clipper 800 and the crew
Re: Spring Shackle bolts
The hardware may not look esthetically pleasing but chances are that the hardware is fine.
Without a protect coating steel in start to show signs of rusting overnight so just because you see rust doesn?t mean that the hardware has been compromised.
A good grade 8 bolt will be around long after the rest of your trailer has rusted away around it.
Oh ya, no grease. Just torque to specification
