Spun My Harmonic Damper Today!!
Status
Not open for further replies.
Skyhawk
This is the strangest thing. Went out to the lake today for a few hours. Heading back to the launch I was traveling at WOT for a few minutes and when I throttled down I heard a loud pop. Obviously concerned I took it out of gear and let it idle so I could open the engine hatch to see what was going on. The engine was making such a racket I though I had threw a valve or rod or spun a bearing.
So I got it on the trailer and got home for a closer inspection. After a few minutes I discovered what had happend, the damn harmonic damper(balancer) was just "floating" on the end of the crank between the pulley and timing cover. Apparently when I throttled down the change in engine speed was enough to shear the key on the crank that holds it in place. Strange as I've never heard of this happening or had it happen to me. I'm actually pleased though the the engine is fine, I thought I'd be replacing it which would have not been good as it only has about 50hrs. on it!!
Skyhawk
Re: Spun My Harmonic Damper Today!!
Edit as my first post is misleading
The damper is actually 2 pcs. The inner portion is what the lower pulley bolts to then there is an outer ring that is pressed on to this with a rubber material in between the 2, making it one piece. What failed is that rubber pice so the outer portion of the damper is what let go. That being said, the lower pulley and inner portion of the damper stayed intact on the crank which is why I didn't throw any belts. The outer portion is the part that is now just floating there.
Ayuh,.... It Happens,....
And,...
You need a New 1.....
Uraijit
Banned
Luckily, they're only about $4 at a salvage yard. I was wondering how the heck you'd sheared the woodruff key, in your first post... :eek:
mkast
When it happened to me, we found someone installed the rounded style key instead of the square one.
brunolund
why rent a puller? they are only ten dollars, and are the same as a steering wheel puller.
Status
