SS Prop for Volvo SX
Chris Yeates
Hey folks,
New to me boat that came with the stock, aluminum prop.
Looking to get recommendations on a SS prop.
I’ve only ever owned outboards and this is my first stern drive. Was looking at a Powertech ELE, PTC model, and the OSS model. No idea the differences or if there’s a different recommendation all together. Those 3 closely matches the diameter of the OEM prop.
Would rather get some solid recommendations before dropping $$. Thanks!
  1. None. Aluminum prop has a few small nicks. Want to upgrade to SS. Looking for overall good performance.
  2. Volvo Penta 3 blade aluminum
  3. 14.5x19
  4. 5k RPM. 52 ish MPH
  5. Volvo Penta 5.0 GXI, with Volvo SX Drive. 270HP, 2008.
  6. 2008 Monterey 214 FSC. 3900lbs
When I switched to the SS I dropped 1" in pitch from the Stock AL Prop. What occurred I had my SS(OMC RAKER) from my previous Outboard on hand, so I had the Hub replaced so it would fit on a VP. I later replaced it with a Merc Enertia. Both props run about the same rpm as the VP AL prop did, but the Boat rode and handled Much Differently with these Props.
I ran into 89retta at the Lake one Day, he saw the Boat with the Enertia on it.
My Avatar shows my boat running the Enertia
89retta
If I remember correctly I gave you a run for your money lol. Also I did pick up an Enertia 19 pitch after that day. Pretty good prop. But sold it and now I'm running a 19 Revolution 4. Have been out lately?
You did, until I started my Motor...
I haven't been out since 2021. The Town Really Effed up the Launch Site, and the Park is now even Worse. Docks are almost Non-Existent. My poor Buick was Sideswiped Last Year, and I haven't moved the Hitch to the Caddy
89retta
They opened up a new launch on the Southside at sundance. It's pretty good and not busy
Years ago there was a Launch at that Rock Canal near Sundance, but about 20 yrs ago, they blocked Canal up. Did they reopen it?
Edit: Looking at Google, it is the same One. And I see the Parking Area. I will have to check it out. Keep this on the QT, or else it will be overloaded
89retta
Yes its the same one. They removed the rocks blocking tha canal. And did a great job on the parking lot
