Starter issue
rowerowe101
I picked up a project boat and the starter is engaging on its own when I turn the battery switch on. I’ve narrowed it down to potential improper ignition switch wiring . My issue is finding the proper Wiring diagrams for an e60tledr evinrude. Has anyone had this issue before and any idea how I can find the right wiring diagram? Internet hasn’t had a match so far and service manual is giving different colors than the wires connecting to the switch.
Check the maxrules web site. They have common wiring diagrams.
There is a table that will give the year of your motor, by the model number. Pick out a wiring diagram of your year and HP if possible, but usually one of about the same year and about the same HP will work as well.
kbait
Check here
The maxrules ----Site has wiring diagram for the remote control and ignition switch.-----Hopefully the previous owner did not apply 12 volts to coils and CD powerpack.
rowerowe101
Haven’t heard of maxrules , thank you. Unfortunately they don’t carry 1996 60 HP
