starter motor not engaging
inlgmouth
I have an 86 Merc xr2 150hp. The starter motor is not engaging the teeth with the teeth on the flywheel to crank motor. The teeth on the starter motor just spins. The starter motor was replaced last year. Could it be a low battery. I'm going to try a different battery. What else may be the problem. Thanks for any help.
Faztbullet
Re: starter motor not engaging
Acme threads are dry. roll bendix up into flywheel and dab a little oil on threads. :)
Silvertip
Oiling the spiral grooves in the starter shaft only allows dirt and debris to gather making the situation worse. Use a spritz of carb cleaner to clean those grooves and then just light hit with a spray silicone lub will do. But also know that you need a fully charged battery to allow the starter to spin fast enough to force the bendix up the shaft. If you have a battery with a weak or dead cell, or the battery is simply discharged, that will prevent proper starter operation. If you don't have a voltmeter on the console, use a handheld voltmeter to check the charging system to make sure its working.
inlgmouth
Thanks for the response. I used a different battery and it started first crank and no problems since. 1st battery is new and supposedly fully charged. Should have tried that before posting. Have another problem now. New thread.
