starter wiring
katt68
good day,
my 3.0l cobra has the following wiring....
coming from the assist solenoid....1 wire going to the small terminal on the actual starter solenoid
another wire coming from the ignition coil to another small terminal on the actual starter solenoid
so, new starter i have has only one small terminal on the starter and the big one.
so, my dilema is.....
can both wires go to the small terminal on the starter solenoid?
Re: starter wiring
good day,
Nope,.... Don't work that way,.... I'm guessin' you Don't have a Marine starter anyways,...
That's why the terminal is missin'....
That terminal powers up the ignition while crankin'....
