(stearing) Wheel, what do I need?
mckevin
The boat (16' tri-hull) is on the way back together with new stringers, deck and transom. Thought I should pretty up the helm while I'm at it. Ordered and received a guage set and new wheel, but my rig must use something unusual.
Aside from being ugly, the wheel is cracked and really needs replaced.
Anyone know what I should be ordering or where? I would like to replace just the wheel if possible.
Photos attached (I hope)
tashasdaddy
Re: (stearing) Wheel, what do I need?
looks to me like it's time to buy the teleflex no feedback rotary system, i don't beleive any one makes those any more, and you may have to relocate the guages.
Ayuh,.......
Those Square Shaft helms are Antiques,+ No Longer Available....... Including the Wheels for them.....
I'd get a New Helm,+ Cable like T's D says.......
Frank Acampora
Old Glastrons used that square shaft steering. They had a pretty nice wheel on them. If you can find an old junker. try to salvage one out of it. The gear is a nice rack and pinion. I have two of them and I am toying with the idea of removing the shaft and having it turned down to standard 3/4 inch taper or drilled out to receive a 3/4 inch tapered shaft so I could use new wheels.
You know, you can do anything you want if you are willing to throw enough time or money at it.
tashasdaddy
that the easy way out, and replace the system.
mckevin32
Replacing the system is a last resort measure, this project is well over budget now!
As everything else seems to be in working order (and I only intend to keep this boat another couple of years) I would prefer to simply replace the wheel if possible.
Ayuh,....... For a Couple Hundred,.... It can All be New.......
tashasdaddy
look at ebay item # 150124064750 don't think you can beat it. for new.
