steel thickness for home made trailer
albertaborn
how thick steel should i use for building a quick little trailer for my 12 ft aluminum and my 7.5 hp merc.
Re: steel thickness for home made trailer
Ayuh,... Thickness of the material is directly related to the other dimensions of the shape used...
Generally speakin',... 1/8" is usually acceptable in tubings,.. 3/16" in structural...
Viking...
If you are using HSS (hollow structural section), then you will have a limited, but acceptable wall thickness.
For example, a 2"x2" square HSS will come in 1/8", 3/16" or 1/4" thickness.
Like Bond-O suggested, the 3/16" will be your better choice, for strength and ease of use (welding, drilling, etc).
Tubing comes in more sizes.
2"x2" square tubing can be found from 16 gauge (.065") up to 7 gauge (.180"), and also 1/4" (.250W).
The size of HSS or tubing for the tongue should match your intended hitch mount, which comes in a variety of widths and ball sizes.
Don't skimp on this part, a strong tongue that runs front to back makes for a strong reliable trailer.
As Bond-O mentioned, 1/8" thickness for tubing is acceptable. Just don't ask too much of the structure by limiting the amount of gussets, cross members, etc.
Good luck!
Silvertip
Why bother. There are many sources for small trailers (Northern Tool for one) and you can't build one that reasonably (unless everything is given to you and seviceable). Plus you don't have the problem of registering a home-made trailer of questionable build quality. There are all sorts of used trailers available as well.
