Steering cable replacement
jerseyboy1983
About 6 months ago, I had a new motor installed. At that time, I was told the steering cable was frozen. And trying to break it free, I stripped the gears in the helm box. Basically, I want to order the new box and cable before I remove the old cable so im not having to lift the motor twice. But the cable does not say the length on it like everyone says it should. I have a 1985 Wellcraft V20. 21 Ft long. Anyone know how long the cable is? And Will any cable work with my Evinrude?
jbcurt00
Re: Steering cable replacement
Lots of good info in here, look around & you might find answers before some one has a chance to give you 1:
How To Measure Steering Cables, iboats.com How To Library
This probably has important info too:
Steering Issue
Is it that ^^^ 1985 Evinrude 150 that is your 'new' motor, or a different new motor?
Might ought to see if someone replies in 1 forum @iboats before starting another steering thread in another @iboats:
Pix always help, what steering setup do you have at the helm? That's the steering box you're asking about, correct?
Which steering setup at the motor, tilt tube?
An engine model # might help, there were a few in 1985:
Does you Evinrude use this style steering hookup:
To this type of tilt tube:
jerseyboy1983
Thank you. That link had everything I needed to know. Thank you again.
