Stencil for Duck Boat?
MCWCA
I have a 15' alum Duracraft that I would like to stencil a shadow grass pattern on. Do any of you know where I can buy a pattern or how to do it yourself? I'm just going to use spray paint. I'm not looking for anything fancy or expensive.
Thanks.
Re: Stencil for Duck Boat?
Ayuh,.... An arm load of Cattails from a roadside ditch,+ a 1/2 dozen rattlecans of the colors of your choice should get the job done....
Home Cookin'
You can get stencils from places like Avery or Cabela's.
As Bondo said, spray across some grass.
But here is what I did to camo a canoe for hunting: painted the hull first with an OD paint (from the mismatched pile at the the paint store and a few squirts of color). If yours is already painted a good base, the better. Then I took my next color (dark brown) and put it in a roller pan; took several bunches of marsh grass, and some leafy branches; dipped them in the paint and slapped them along the sides, floor etc in a vertical pattern. "Indian paint brush." had a little Jerry playing to inspire the earthy artistry. Then put another color on top.
Ducks don't need reality; the important thing is to break up sillouette. A well-painted side of the boat (14" freeboard?) will only be seen by the ducks swimming up to your boat. Even a stooling duck when it gets in range is aproaching at 30 degrees at the lowest. (As you can tell, I have discussed the issue with my hunt club members, who brush our blinds solid from the ground up the first 3'--we have the most well hid boots on the marsh for those swimmers!)
