Sterndrive oil question
hazwild
I have a merc 3.0 stern drive the book says to use high performance gear oil,i have premium gear oil.Is there really a difference??
Thanks in advance
Re: Sterndrive oil question
Ayuh,.....
High Performance is Syn.oil,....
Premiun is Dino oil,......
Either will work, but I prefer Syn. oil myself..... I use Mobil 1, 75W-90....
HT32BSX115
Since the drive is cooled by water and is usually cool, you'll actually get lower friction in the drive using synthetic oil in it. (Once the drive is up to operating temp the difference although significant is not as much)
After you stop the drive it cools fairly quickly (after all it's in "cold" water)....
It's probably a good idea to use either the Mercury, Volvo Penta or any good synthetic gear oil in the drive. Mercury and other marine synthetic oils will actually allow *some* albeit very little, mixing with water and not separate to continue adequate lubrication until you can get it changed. I don't know if the non-marine gear oils will do that....
Since this is something you may do once every year or every other year the cost of the oil is not very significant.
Regards,
Rick
hazwild
Thanks for info guys.They were both marine grade gear oil,but i did go over to west marine and get the quicksilver hp gear lube..
BOB:)
Make sure you change the gear lube in the reservoir also.
Mkos1980
I have been running Mercs HI-PO Oil. Blue color? Is this oil a high performance dino, blend, or syn oil?
Like Bondo stated earlier in this thread, High Perf. is Synthetic
rodbolt
like DonS said,
if it has a resevoir and your using HP gear lube its imperative to clean the "mud" out of the resevoir at least yearly.
its the anti wear additives that are falling out of solution. I still havent figgured out how it defies gravity but its always there.
