STIHL FS 36 spec. ?
Ben Konopacky
Need to know the air gapspec.for electronic (breakerless) mag ignition .Thats the gap between coil armatere poles (2) and fly-wheel magnets.
Re: STIHL FS 36 spec. ?
Just want to make it run.... use a matchbook cover for the thickness. That has worked for me in the past kind of handy to know and non-technical.
bjcsc
Check out the manual online <a href="http://www.stihlmanuals.w1.com/stihl_ownersmanuals/FS36_Manual.pdf"target=_blank>here</a>, but he only gap spec I see is the plug at .03".
Paul Moir
I believe it's .2-.3mm (.008-.012"). At least it is for the 036 QS and AVSEQ.
That's one standard size business card. ;)
