Strange noise on Bravo III
CurrentObsession
2000 Formula 400ss
Port side sounds like the bilge blower turns on when shifting into forward. No noise in neutral or reverse. Very strange. All seems fine other than the noise. Just pulled it out of the water for the winter. Lube oil is not milky, looks new and green. My mechanic was there and played around turning and yanking on the props trying to determine what might be a dead giveaway like broken gear teeth but didn’t he says nothing seems out of the ordinary.
Anyone ever have something like this happen?
Swap the drive, if noise moves with drive it's in the drive
