Stringers and Foam
Seadoomanls
What is the purpose of the stringers in a hull?
Is it to help with flotation or to help keep the boat conformed correctly or simply just to hold the deck up?
What about the foam? I mean does it not do more damage when wet than not having it at all?
I have a 1986 Bass Boat that I want to do the full resto to next winter so I am trying to save up the approximate $1600 I figure I will need.
Oh, btw, my Bass Boat sank last may and I thought what I did was tear it apart and rebuild it. But after reading on here, I did not do anywhere near a rebuild. I have not even looked into the deck and I already know I need new decks, transom, stringers and foam removal. Also, I am going to make my bass boat a center console when I do it!
Since the sinking it has been run again. I use it to fish 2 or 3 times a week!
Was just wondering those few questions. Thnx!
Re: Stringers and Foam
Stringers maintain the strength and integrity of the hull. PROPER installation of foam and flotation products is key to keeping things dry and draining below the deck ;)
cedarjunki
in some cases the foam is the structural integrity too....
Ayuh,... It's the Backbone of the hull....
Just like Your bones,.. Without 'em, you're a pile of jelly...
erikgreen
I'm a pile of jelly WITH my bones. Maybe I need a stringer job?
