Stringers, is the juice worth the squeeze?
MR nova @#25
I just removed the cabin floor from a 1985 Tiara 3100, because it was soft. 1/2 plywood glass on top bare plywood underneath. My plan was to remove the plywood stringers and bulkhead and redo it all in coosa. After I remove the bulkheads, I saw the stringers are literally an upside down hollow box with glass over the top.
When you hammer on the stringers there's no dead spots or delamination. I ran a camera down the length of the stringers the woods black but its intact. My concern is what benefit will I gain by removing solid stringers from a cabin and replacing them??1000001926.jpg
Texasmark
When you hammer on the stringers there's no dead spots or delamination. I ran a camera down the length of the stringers the woods black but its intact. My concern is what benefit will I gain by removing solid stringers from a cabin and replacing them??View attachment 416491
The fiberglass mat is surely covering wood stringers. If the resin has completely sealed the stringer when the mat was installed and hasn't been damaged, then I'd say you are good to go. As Scott mentioned a few inspection holes wouldn't hurt......ensure you seal them up good when finished looking.
JASinIL2006
My boat has stringers and bulkheads like yours; mine are thick fiberglass boxes with foam inside. I had to remove mine back by the transom, and I was able to cut out a section of the stringers and then glass them back in. Worked very well.
