stubborn start '74 merc 1150
I got my carbs not flooding and cleaned, new floats. I noticed It's hard to get going at first. I just inherited the boat, but I recall it taking a while to start when cold but then when warmed up it's good. Testing, I blew some air through the tube to the main jet on each carb, to get the carb itself primed?, starts pretty quickly. If I don't, it takes ages to get it to fire. Then it runs okay. Next start is easier.
Sooo my question.. What should I look into. fuel flows really well.
Alumarine
Do you use the choke and fast idle lever when trying to start it cold?
Usually the choke on those is activated by pushing the key in.
It has a choke button above the key, yes, fast idle lever as well.
What i did was just blew some air at the fuel bowl vent, then it starts pretty easily. Otherwise, it's a bear.
Update: I went to start it this morning, to try a couple things another forum thread suggested, pumped the bulb extra hard, made sure the choke was 100% closed on both of the top 2 carbs. Took about half a minute and required manually added fuel. Fired up nicely. Then I notified my bottom carb vent was slowly seeping from ththe vent. So I think it needs one more float. I just rebuilt the distributor with a known good trigger. Sounds good once it starts.
This was my grandfathers boat and I used to use is when I was young a lot, but there’s a lot I forgot.
When I start it I put the idle lever all the way up and drop is down right away so it doesn’t over rev and blow up. From cold should I need to do this or should it start with it in a lower position once all the kinks are worked out?
Its already working awesome compared to when I got it officially, just trying to make sure I don’t kill it trying to fix it. A working used boat would be so much cheaper, stupid nostalgia!!
Thanks everyone! :)
