Stuck Hinge Pin on Merc Outdrive
nkswell
Any Ideas On how to remove a stuck hinge pin on a Merc Alpha 1 gen 2 outdrive? I tried a breaker w/ a pipe and some heat but I'm scared I'll stip-out the socket which is in bad shape already. If anyone has any ideas I'll sure appreciate it. Also what if it strips out?
Re: Stuck Hinge Pin on Merc Outdrive
Ayuh,... Welcome Aboard,... They're set in lock-tite,... Heat the pin itself some more...
