Stuck in forward gear
Daddy O
I removed the sterndrive to replace the u-joints, and gimbal bearing. Placed the shifter in forward gear. After reinstalling it. The drive is now stuck in forward. No matter where the shifter is. It will even start in while it is like this. Any ideal?
Rinker 180
4.3L OD608617
Alpha One Mercruiser OD575222
Bt Doctur
Re: Stuck in forward gear
shift arm slipped out of the slider?, need to pull the drive to inspect.
Daddy O
Thanks... figured that's what I had to do. Just waiting for the rain to let up. No garage.
The link was good, lots of help!
Daddy O
You guys were right! Removed the drive, placed the shift arm back in place. reassembled. Shifts fine.
Thanks for 88 help! !8)8)
