Suggestions for removing oil spots from driveway?
Status
Not open for further replies.
scoutabout
Going to get the driveway resealed soon and wanted to deal with some existing oil spots prior to. Worst area is about the size of a salad plate. Other areas just a few drips here and there.
All suggestions welcome (including getting the dang steering rack seals fixed on the vehicle...)
kmarine
Re: Suggestions for removing oil spots from driveway?
Prior to seal coating i burn off oil stains with the propane torch i use for shrink wrap. This allows the sealer to adhere to the asphalt.
scoutabout
Thanks k - interesting approach I hadn't thought of...
R Socey
TSP workes good. If there are risidual stains phosphoric or muratic acid will devour them. I would scrub, and powerwash first - try to avoid using acid but it absolutely works if all else fails. Dishwashing liquid can also be used, and get the dang steering rack seals fixed!
ajgraz
^^^ Invite this guy over to powerwash. Then complain that he ruined your driveway.
Note: This is a joke based on the crazy lady thread :p :facepalm:
R Socey
:D Evil lady would be more correct!
korygrandy
ROFL. Yeah Get R Socey's pressure washer...from what I've heard his setup is quite powerful and you have more potential of getting a full replacement driveway after routine maintenance fails! :facepalm:
fat fanny
I f all else fails use a grinder or wire wheel
Fireman431
Muriatic acid (for pools) then pressure wash.
On concrete driveways, I make a watery paste of OxyClean and let it sit on the spot. Not sure how effective that is on asphalt.
foodfisher
Petroleum based seal over petroleum based spills over petroleum based surface. I suggest a pressurewash and let dry.
bigdee
On concrete I use cat litter and scrub it with a brick...I don't know if this will work on asphalt.
no704
^^^^^Kmarine sounds like the way to go. Depending on how soaked in it is? Just spots or soft areas? Might need new stringers???
Status
